Aaron,
You don't mention how fast you want to run the ADC. Given that it is a flash, the implication is that it needs to run fast. One issue is that comparator gain is proportional to overdrive. As a result, the comparator that needs to make the key decision is also the slowest comparator and you can't sample until the comparator decides. Another issues is that the input signal is not stable, that is, without a S/H the input can slew while the comparators are trying to decide. Due to delay, process variation, etc. more than one comparator can be saying "I'm the one". The bottom line is that a flash ADC without an S/H is almost always slower than a flash ADC with a S/H. We haven't even gotten to the issue practical issue of layout, most designs are folded to improve the form factor. Folding the ADC into four banks of 6 bit ADCs will cause clock skews that will post comparator sampling unfeasible.
