Jul 25th, 2024, 2:18pm
Low drop out voltage regulator (Read 207 times)
analog geek
Nov 16th, 2013, 4:53pm
I am working on 90 nm LDOs. I am working on to convert 1.8 v to 0.8 volt range..any suggestions will be helpful.
analog_rf
Universe
Re: Low drop out voltage regulator
Reply #1 - Nov 26th, 2013, 6:34am
please let us know what you need specifically. Eg:what specifications you need to achieve ,what application is it going to be used(eg:pll vco etc). Noise requirements,PSRR.
venkatesh juturu
vellore
Reply #2 - Nov 27th, 2013, 9:10pm
hi sir,
i am designing VCO in cadence-virtuoso-ADE using gpdk180nm
for the ckt shown as i got op waveform as shown and i changed corresponding w/l ratio and vdd i got another waveform
my question how to stabilize the output waveform
help in this regard
thank in advance
venkatesh juturu
vellore
Reply #3 - Nov 27th, 2013, 9:11pm
the output waveform
venkatesh juturu
vellore
Reply #4 - Nov 27th, 2013, 9:13pm
the modified w/l output
dave_dave
Reply #5 - Nov 27th, 2013, 11:40pm
hi venkatesh,
what happens if you increase your simulation time? It looks like your system is not settling within your chosen simulation time.
You should also have a look at the amplitude of your signal: it's in the picovolt range, so it is not really a signal at all.
p.s. the topic does not really fit to LDOs Wink
greets
dave
analog_rf
Universe
Reply #6 - Nov 29th, 2013, 8:12pm
looks like with increased w/l your circuit is indeed oscillating.Please increase the simulation time and allow the output to settle to its final value which will be limited by the non-linearities of the circuit.what vco topology are you trying to design and what are your design requirements?eg:output freq,output phase noise@1Mhz etc.
