Dec 13th, 2025, 1:13am
on current reduces below e-11 when interface trap is introduced (Read 5016 times)
biju4u90
Feb 07th, 2014, 11:38am
why the on current reduces to e-11 order from e-6 order when an interface trap level is introduced in SiC power mosfet??
Re: on current reduces below e-11 when interface trap is introduced
Reply #1 - Feb 25th, 2014, 12:52pm
I don't think you've given us enough information to understand your question.  Are you talking about introducing an interface trap level in the device model for the mosfet?  or doing something in the fabrication of the device?
biju4u90
Reply #2 - Mar 9th, 2014, 9:07pm
Yes. The problem occured while trying to introduce interface traps in mosfet. its not fabrication, just simulation using atlas
biju4u90
Reply #3 - Mar 9th, 2014, 9:08pm
is there any limitation for the oxide thickness that can be used while introducing interface traps in a mosfet simulation?
