Create an include file called (say) stats.scs containing:
statistics { process { vary mydc dist=gauss std=1u } }
Then have your voltage source in your schematic with a dc value of "mydc". In ADE you'll end up with a Design Variable called mydc - set the value of that to the mean value you want (the 1u in the file above is the standard deviation, so set that to what you want). Use Setup->Model Libraries to include the stats.scs file.
Then in ADE XL (if in IC61X) set the run mode to Monte Carlo, or if in IC5141 you'd do this from ADE via Tools->Monte Carlo.
