May 18th, 2024, 10:33am
comparator recommendations (Read 4159 times)
aaron_do
Mar 11th, 2014, 10:22pm
does anybody know of a good comparator design? I'm looking for the fastest, meanest, ugliest design around. Right now I'm using one similar to that detailed in "A Low-Noise Self-Calibrating Dynamic Comparator for High-Speed ADCs" IEEE ASSCC Nov 2008.
thanks,
Aaron
AnalogDE
Re: comparator recommendations
Reply #1 - Mar 13th, 2014, 4:32pm
Interesting paper.
I recently designed a pretty simple high speed comparator borrowing the basic circuit from a paper by Yin JSSC Feb 1992.
Basically a input diff pair followed by a cross-coupled latch with a pretty simple clocking circuit.
aaron_do
Reply #2 - Mar 13th, 2014, 6:06pm
Thanks for the tip. I had a look at it, but I'm not sure it would be as fast as the one I'm using...I also tried the strongarm comparator, and the one I'm using turned out to be around 2x faster...
thanks,
Aaron
Reply #3 - Mar 26th, 2014, 11:39am
latching or not?
clocked or not?
Some of the most efficient designs integrate the comparator with the next stage latch
aaron_do
Reply #4 - Mar 26th, 2014, 8:02pm
Clocked and Latched.
Basically the one I'm using has a first stage "dynamic preamp" and a second stage latch. The dynamic preamp's output is reset to VDD with PMOS transistors, and then on the clk signal, the input diff-pair turns ON and the PMOS load turns OFF which pulls the output CM down to ground with some differential gain along the way. About halfway down, the preamp triggers the next stage latch. Because the PMOS load is OFF, the gain of the preamp is very high and it uses little power because it is dynamic.
Aaron
