May 11th, 2024, 12:18am
what happens at low temp (Read 649 times)
psdjonly
Mar 13th, 2014, 11:32am
Hi All,
We usually care about how high the ambient or die temp is, sometimes we choose 85C or 150C as our datasheet max temp.
At high temp, data stored in the memory could be lost, modeling can be not accurate, leakage goes high...
And here comes the question, what could go wrong at very low temp so that we usually want to limit it to be -40C.
What in the manufacturing process can allow us to go lower than that?
AnalogDE
Re: what happens at low temp
Reply #1 - Mar 13th, 2014, 4:37pm
If you're working with memories your worst performance can occur at the temperature extremes -- memory cell characteristics usually have some sort of tempco, hence the spec limits on temperature.
Logic could also have issue at cold... If the logic gates speed up too much you run into hold timing violations.
Reply #2 - Mar 18th, 2014, 4:21am
« Last Edit: Mar 20th, 2014, 1:02pm by Forum Administrator »
