Sep 15th, 2026, 4:24pm
Calibre with PSPICE netlist (Read 2846 times)
Buyilehu
Apr 15th, 2014, 1:33pm
  Got a question for Calibre PEX tool. After PEX is done, the created Spectre netlist uses the net names from layout instead of from the input netlist. This causes trouble because the layout net names are randomly created and don't have meaning to me. How do i set it up so that it uses net names from the input netlist.
 The Calibre help document says in the Inputs > Netlist section, if source netlist is specified, then the extracted netlist should use names from this source netlist. But the result still uses the layout net names.
  I am using the PSPICE source netlist.
 Please help.
Thank you!
x.q.w.
