May 1st, 2024, 10:15pm
DNL/INL Simulations for my ideal behavioral ADC model (Read 83 times)
eternity
May 01st, 2014, 2:10am
   I have been trying to plot DNL/INL for my ideal behavioral model of SAR ADC. I have my whole system (except the capacitor DAC block) implemented in Verilog-A.
   I have added the blocks from ahdlLib of Spectre to compute INL and DNL. The results that I see after a looong simulation doesnt make any sense to me. So could any of you help me in guiding the right way to perceive these results.
Details: I am designing a 10 bit SAR ADC. So I have given the input ramp ranging from 0 to 1V in [1024*5*(1/sampling_rate)] seconds. I gave NO_OF_CONVS constant as (1024*5), NO_OF_CODES constant as 1024 in adc_dnl_10bit block that I customised from ahdlLib.
Issue-1: The result that I get as my DNL output is directly superimposing on my ramp input. The result says the maximum DNL is at code 1. I am sure the result is wrong and I dont know why at the moment. The digital output of my ADC is given as input to adc_dnl10bit block. Is it right or?
Issue-2: I am not able to write the result to the filename I mentioned in the adc_dnl_10bit verilogA file.  The code syntax is out_file = $fopen( "%C:outp_dnl.dat" )
Eternity.
Re: DNL/INL Simulations for my ideal behavioral ADC model
Reply #1 - Jul 8th, 2014, 7:39am
I don't think you've given us enough information to help you.
Should NO_OF_CONVS mean anything to us?  Do we need to have access to adc_dnl_10bit from ahdlLib?  Can you post any of your modules?
For issue=2, have you tried using $fopen of a simpler filename?  That is, just "outp_dnl.dat"  Is the problem with opening the file, or with writing to it?  Perhaps %C doesn't work, or maybe ":" is a reserved character.
weber8722
Reply #2 - Mar 1st, 2015, 11:00am
what may also help is not only using adc or dac from ahdllib, but also the ahdllib measurement blocks for inl and dnl. Very nice modules, also working with a ramp.
Bye Stephan
