Oct 18th, 2024, 1:57am
Writing to .csv while doing corner in ADEXL using OCEAN. (Read 2266 times)
VINAY RAO
May 05th, 2014, 9:11pm
Hello all,
I am doing corner analysis for my LNA and I have got around 15 corners. So I want to record each response in .csv file. I selected only few corners and saved OCEAN from ADEXL and it has got following command for corner as follows.
ocnxlCorner( "C0"
("model" "/home/vinay_rao/library/Models/Spectre/L65LL_RVT12_V101_RF.lib.scs" ?section "\"tt\" \"ff\" \"fnsp\" \"snfp\" \"ss\"")
     My question is “Are there any options in OCEAN which can track each corner's response and then automatically save it to .csv”? I  am trying to avoid FOR loop kind because it becomes very messy if I have to include all the corners. I am new to OCEAN, so any   kind of suggestion would be appreciable. Thank you.
Vinay Rao.
