Jul 20th, 2024, 8:18am
capacitive voltage divider circuit query (Read 1779 times)
eternity
May 11th, 2014, 7:54am
 I have a small doubt regarding  capacitive voltage divider(2 capacitors in series) circuit. Will the votlage gets divided by half in the middle arm if I supply a voltage source in the top end of top capacitor? Theoretically, it should be possible but I am not able to see that happening in the CAD tool I am using.
I am not sure whats happening. Can anyone here help me out
Eternity
Re: capacitive voltage divider circuit query
Reply #1 - May 11th, 2014, 9:54am
You need to have a DC path to the center node. Without that it will not simulate easily.
eternity
Reply #2 - May 11th, 2014, 12:31pm
I figured out the issue through your help. Thanks.
