Apr 30th, 2024, 12:28pm
$dist_normal (Read 6536 times)
fullstop
$dist_normal
May 24th, 2014, 2:54pm
Hi ,
I am trying to generate random  number normally distributed at every  time stamp of my transient simulations. this is module I am using.
`include "constants.vams"
`include "disciplines.vams"
module distcheck (pinout) ;
electrical pinout ;
integer seed ;
real rrandnum,counter=0.0 ;
analog begin
@ (initial_step) begin
seed = 0 ;
counter=counter+1;
rrandnum = abs($dist_normal( seed,0,1)) ;
V(pinout) <+ rrandnum;
end // of analog block
but when i check the output it is giving me weibull and not normal distribution,
can anybody please help me on this
thanks a lot in advance
boe
Re: $dist_normal
Reply #1 - May 26th, 2014, 5:14am
Fullstop,
will NOT generate a normal distribution.
- B O E
fullstop
Re: $dist_normal
Reply #2 - May 26th, 2014, 6:39am
Hi BOE,
thanks for the reply.
Can you please help me how that can be done. I want to generate a random number for every time step of my transient simulation.
fullstiop
boe
Re: $dist_normal
Reply #3 - May 26th, 2014, 7:07am
Fullstop,
First of all, taking the absolute value is definitely wrong. I suggest
rrandnum = $rdist_normal(seed, 0, 1);
- B O E
fullstop
Re: $dist_normal
Reply #4 - May 26th, 2014, 7:36am
Hey BOE,
Thanks a lot, infact that was the problem.
There is one more issue.
I think it is generating a new random number at every iteration at every time stamp. Isn't it possible like it only generate a random number only when time stamp is increased and not at every iteration during transient simulation. It is taking a lot of time
thanks
fullstop
Re: $dist_normal
Reply #5 - Jul 8th, 2014, 7:58am
Perhaps that's a bug in your simulator?
You may be able to print the value with
 $debug("rrandnum=%g at time=%g\n", rrandnum, $abstime);
and see if you get different values at the same time.
