Apr 29th, 2024, 2:47am
Measuring phase noise of ring-oscillator using spectrum analyzer. (Read 2914 times)
Colombo
Jun 02nd, 2014, 12:41pm
Hello guys,
I'm measuring the phase noise of a ring-oscillator that consists of cmos inverters. A spectrum analyzer is been used to measure the frequency spectrum, as can be seen in the figure bellow. The spectrum was measured using different values of RBW (from 100 Hz to 510 kHz) and a fixed span of 10 MHz. The oscillation frequency of ring  is around 330 MHz.
As expected, reducing RBW the noise floor is reduced.
The phase noise is calculated as follow:
Phase noise at offset frequency f1 = Power (f1) - Power carrier - 10*log(RBW).
However, the obtained phase noise at 100 kHz and 500 kHz of offset is a strong function of RBW.
Which data is the correct one? is for RBW = 100 Hz since the noise floor is the lowest? How can I understand these results?
It seems that the power different between the carrier and the offset depends very weakly on the RBW, and the last term of the equation is affecting the calculation.
Thank you very much.
Colombo
Re: Measuring phase noise of ring-oscillator using spectrum analyzer.
Reply #1 - Jun 2nd, 2014, 12:44pm
The values of the calculated phase noise are:
« Last Edit: Jun 2nd, 2014, 3:49pm by Colombo »
