Jul 23rd, 2024, 2:26pm
how to build EFT (Read 3381 times)
bsaqycx
Asia
how to build EFT
Jul 06th, 2014, 6:50pm
Dear all,
I've no idea how to build EFT test modeling. EFT means that the high voltage pulse(+-4000 V, lasting for ~100 ns, 100kHz) is introduced to the input AC source and the system output should not go down to 0 V.What's more, the introduced pulse could affect every pin of the chip because of the small size of the whole system.
For now, it's very difficult to predict the performance on this issue without proper testbench. Now I'm looking forward to some advice from you. Thanks in advance.
Re: how to build EFT
Reply #1 - Jul 7th, 2014, 5:38pm
bsaqycx
Asia
Reply #2 - Jul 7th, 2014, 9:26pm
Thank you very much for your help!
I'm wondering how to build such EFT pulses generator for simulation. I've no idea about the storage capacitor should be used.
Reply #3 - Jul 8th, 2014, 12:06pm
In the real world instrument companies sell EFT generators.
For simulation, you should be able do a PWL generator to get an approximate signal.
