Jul 4th, 2025, 4:13am
Virtuoso & Verilog/VHDL (Read 4092 times)
tdlrali
Jul 23rd, 2014, 7:10am
I'd like to use either Verilog or VHDL to describe testbenches in Virtuoso (IC6.1.5). I've successfully simulated a VerilogA module in spectre, but still I have a few questions.
1) Does Spectre only support VerilogA? Do I have to use the AMS simulator (from IUS) to use VerilogAMS / VHDL-AMS?
2) What's the status/support of the different languages - VerilogA, VerilogAMS, VHDL-AMS? Ideally, I'd like to use VHDL-AMS, because I personally like VHDL better than Verilog.
3) Can I use generic port widths? The Virtuoso Schematic Editor does not seem to support this...
Thanks for your help!
boe
Re: Virtuoso & Verilog/VHDL
Reply #1 - Jul 24th, 2014, 1:30am
tdlrali wrote on Jul 23rd, 2014, 7:10am:
Yes.
In principle, Cadence supports both Verilog-A(MS) and VHDL-AMS. However, not everything that is in the LRMs will be supported (and there may be differences between the two language groups).
I do not think you can do this with Virtuoso Schematic Editor. But if you do not need a schematic (i.e. use such cells in HDL code only), you can.
- B O E
