Hi, AZADBAKHT,
" R=[√(L/C)]*Q "
This equation is only approximately correct @SRF(Self-Resonance Frequency), where omega=1/sqrt(LC). The SRF is definitely not your oscilation frequency.
You should use R=omega*L*Q to estimate the impedance, where the omega is the oscilation frequency you want.
The different R values roots in the Series-Parallel Transform.
AZADBAKHT wrote on Aug 15th, 2014, 6:36am:Hi aaron_do
yes,i know this resistance it's parasitic model for tank.
but,in you're opinion i can build an tank with 750 ohm resistance(parasitic model)?
at RLC parallel tank:
R=[√(L/C)]*Q >>>> (L=1nH , C=10fF)
the formula illustrate for have R=750 must Q is high!!
you think i can build the this tank??
