aaron_do
Since you know what post-layout simulation is, you know how to get the parasitics at all the nodes. However, you need some way to extract inductance too. Try an EM simulator like ADS momentum. As loose-electron implied, if you model the inductor as just an ideal inductor with a parallel resistance at that frequency, your results will be wrong.
regards, Aaron
