May 3rd, 2024, 9:59am
Problem on simulating VerilogA comparator model with PSS analysis (Read 3330 times)
AMSA
Aug 19th, 2014, 7:20am
Hi guys,
I never used VerilogA. I am trying to learn that so that I can design a feedback loop using this.
I wrote a small code from a Verilog A tutorial for a comparator.
After implement it, I tried to simulate a simple circuit - Vpulse shaping a triangle wave and a vdc source to see what would appear at the output.
I used a PSS analysis and an error appeared:
It says that PSS doesn't support behavioral models with hidden states. Is that true? There is any way to escape from this error and use PSS analysis?
What is hidden states?
Re: Problem on simulating VerilogA comparator model with PSS analysis
Reply #1 - Aug 19th, 2014, 10:40am
AMSA
Reply #2 - Aug 19th, 2014, 2:32pm
Hi Ken, I have read what you have posted but to be honest it didn't said nothing to me. That is, I didn't understand how to take the hidden state from the comparator that I was trying to design.
If you could tell me how to change my comparator code in order to eliminate that hidden state I would Appreciate:
And if you don't mind please feel free to highlight the change?
Regards.
Reply #3 - Aug 20th, 2014, 10:47am
I recommend that you not post code using images. It makes it harder to quote the code, which is often needed to help you.
You should change your model as follows:
analog begin
    @(cross(V(in)-thresh))
    V(out) <+ (V(vdd) - V(vss))*transistion((V(in) > thresh), 0, tt) + V(vss);
This will fix several problems in your model, one of which is the hidden state problem. The other problems are:
1. It would output the wrong value at the start of the simulation (before a threshold crossing occurs)
2. You should never pass a continuous signal (in this case either V(vdd) or V(vss)) through a transition function.
