Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 8
th
, 2024, 1:57pm
Home
Help
Search
Login
Register
PM to admin
Measurements
Phase Noise and Jitter Measurements
› How to guide for noise_table usage in VCO
Previous topic
Next topic
How to guide for noise_table usage in VCO (Read 5248 times)
kg_maclean
Aug 20
th
, 2014, 3:02pm
I would like to generate a noise table file for an all transistor VCO and then use that noise_table file in a closed loop PLL simulation using
veriloga models.
Is there a how-to guide or an example veriloga file showing the usage of the noise_table function and the exact required format for a
noise_table file?
IP Logged
raja.cedt
Re: How to guide for noise_table usage in VCO
Reply #1 -
Aug 21
st
, 2014, 3:32am
Hi..
Why don't you save noise date into CSV file and import this table into VDC. Which works pretty fine for all PLL sims...
IP Logged
kg_maclean
Reply #2 -
Aug 21
st
, 2014, 11:41am
Thank you for the suggestion which helped very much.
I was not able to get spectre to accept a noise file which had been created in CSV format, but I used trial and error on the other file formats. I found that if I selected SPECTRE as the output file type in
my VCO pnoise simulation and then used the file created with the .in file name extension that spectre would run and generated a
similar
output ac noise spectrum to what I saw in the pnoise simulation.
The spectrum was not identical in that there is an offset of +0.535dB at all frequencies between the small signal ac noise simulation and the original pnoise simulation.
IP Logged
raja.cedt
Reply #3 -
Aug 22
nd
, 2014, 1:54am
Could be some thing wrong in sim, because here ac sim is not even calculating any thing other than simply displaying .csv file(I don't know about .in file)
Check how do you plot spectrum...
Raj.
IP Logged
kg_maclean
Reply #4 -
Aug 22
nd
, 2014, 6:31am
Hi Raj
I figured out the cause of the offset. The pnoise result for the vco is displayed in dBc/Hz referred to the rms amplitude of the signal (at the vco frequency). When I save the pnoise data to a .in.spectre file the raw amplitude (in V/sqrt(Hz)) is saved, which must be referred to the actual rms amplitude to get the correct magnitude in dBc/Hz. When I did this additional step in my small signal ac simulation the magnitude was correct.
Thank you very much for your help on this.
Ken
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
»» Phase Noise and Jitter Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
