May 2nd, 2024, 6:55am
Verilog-A defined units in Spectre (Read 1905 times)
adelaid
Sep 03rd, 2014, 3:45am
Hello,  I am trying to do the model of an optical phase shifter in Verilog A. For that I defined the following disciplines:
// Optical Discipline
nature Losses
access = Loss;
abstol = 1e-6;
units = "dB";
endnature
discipline optical_losses
potential Losses;
enddiscipline
nature Phase
access = Phas;
abstol = 1e-6;
units = "rads";
endnature
discipline optical_phase
potential Phase;
enddiscipline
the problem is that in spectre when I simulate then the module, the units are not corresponding with what I defined here. Instead of Loss(dB), and Phas(rad)  it appears  Loss(Loss) and Phas(Phas).  What can be the problem??
Thank you in advance.
boe
Re: Verilog-A defined units in Spectre
Reply #1 - Sep 3rd, 2014, 10:45am
Adelaid,
the viewer shows the wrong units? Then it is a tool issue...
- B O E
