Jul 22nd, 2024, 11:31pm
External Input Variable (Read 3451 times)
MMI
Columbia, SC, USA
Sep 15th, 2014, 6:17pm
I am trying to use external input variable as an input to an RC circuit module to incorporate self heating effect in my model. Can anyone help me with this? What i am trying to do exactly is, i have a model in which i want to include an RC circuit module whose input or the source should be Power = V*I already exist in my model.
I would highly appreciate any help regarding this.
Thanks You.
« Last Edit: Sep 15th, 2014, 9:12pm by MMI »
Re: External Input Variable
Reply #1 - Sep 23rd, 2014, 2:17pm
Is your model written in Verilog-A?
You can measure V and I with dependent sources and get the product V*I, but it's a little tricky to get the updated temperature back into the model, if it's a built-in model in the simulator.
If it's Verilog-A, then it's easy to do, and there are examples in a couple open-source models (Mextram, Hicum, etc.).
MMI
Columbia, SC, USA
Reply #2 - Sep 24th, 2014, 7:37pm
Thanks for your reply. My model is written in Verilog. I will look into those models.
