May 2nd, 2024, 1:41am
fixed time step in Verilog-A? (Read 3131 times)
fgcsk
Oct 06th, 2014, 11:50pm
Is there any way to have a fixed time step in Verilog-A?
I know $bound_step can limit the time step to a certain amount, but it does not guarantee the time step is fixed if I understand correctly.
Actually I just want to implement something like this:
Y = Y + dYdt*timestep
I know Y=idt(dYdt, 0) can do it, but at some events I also need to directly modify Y, and idt() is an analog operator that is not allowed to do so.
Any suggestions?
Re: fixed time step in Verilog-A?
Reply #1 - Nov 13th, 2014, 10:22am
There is a reset argument to idt() that allows you to set the output to zero; can you use that?
What you're asking for is a little tricky; what happens when the simulator fails to converge at a timepoint (due to nonlinearities in other parts of the circuit) and backs up to take a smaller time step?  Will it know how to back out the direct modifications you made to Y ?
fgcsk
Reply #2 - Nov 22nd, 2014, 11:54pm
Thanks for explaining why there is no fixed time step.
The reset argument of idt cannot help, and I've already come up with a way to solve this problem, which is to separate the total Y into two variables.
One is the idt(), and the other one is the modification.
