Apr 30th, 2024, 10:50am
Spectre_simulator : Post layout verification problem (Read 10794 times)
ghegde
Singapore
Oct 09th, 2014, 9:57pm
       I am facing a problem while dong a post layout simulation of  a simple inverter chain.I ran a transient analysis on current through voltage supply node(minus terminal) with an intention to know the current flowing through the circuit at different instant of time.
Unfortunately Spectre complains that "Analysis `tran' was terminated prematurely due to an error."I am not able to understand what this error is and how to resolve it.
Also there are errors like "ERROR (CMI-2049): I0.rvdd!_438 of Inv_Chain: Value of `leff' should be greater than zero.".What it means??
I have pasted the last few lines of out put log and attached Test bench circuit.
Please note that there is no error reported for  transient analysis for input signal and out signal.
Any help to understand this issue or to resolve is greatly appreciated.
Thanks in advance,
   ERROR (CMI-2049): I0.rvdd!_494 of Inv_Chain: Value of `leff' should be greater than zero.
   ERROR (CMI-2049): I0.rvdd!_495 of Inv_Chain: Value of `leff' should be greater than zero.
   ERROR (CMI-2049): I0.rvdd!_496 of Inv_Chain: Value of `leff' should be greater than zero.
   ERROR (CMI-2049): I0.rvdd!_497 of Inv_Chain: Value of `leff' should be greater than zero.
Notice from spectre.
   336 notices suppressed.
   70 warnings suppressed.
Time for parsing: CPU = 29.995 ms, elapsed = 37.5192 ms.
Time accumulated: CPU = 552.915 ms, elapsed = 610.33 ms.
Peak resident memory used = 61.6 Mbytes.
Transient Analysis `tran': time = (0 s -> 100 ns)
Notice from spectre during IC analysis, during transient analysis `tran'.
   Bad pivoting is found during DC analysis. Option dc_pivot_check=yes is recommended for possible improvement of convergence.
DC simulation time: CPU = 29.996 ms, elapsed = 29.5141 ms.
Important parameter values:
   start = 0 s
   outputstart = 0 s
   stop = 100 ns
   step = 100 ps
   maxstep = 1 ns
   ic = all
   useprevic = no
   skipdc = no
   reltol = 10e-06
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   errpreset = conservative
   method = gear2only
   lteratio = 10
   relref = alllocal
   cmin = 0 F
   gmin = 1 pS
Output and IC/nodeset summary:
              save 1
   tran: time = 2.507 ns    (2.51 %), step = 18.71 ps    (18.7 m%)
   tran: time = 7.897 ns     (7.9 %), step = 498.6 ps     (499 m%)
   tran: time = 12.5 ns     (12.5 %), step = 43.5 ps     (43.5 m%)
   tran: time = 17.59 ns    (17.6 %), step = 238.2 ps     (238 m%)
   tran: time = 22.52 ns    (22.5 %), step = 24.45 ps    (24.5 m%)
   tran: time = 27.59 ns    (27.6 %), step = 382.1 ps     (382 m%)
   tran: time = 32.52 ns    (32.5 %), step = 36.47 ps    (36.5 m%)
   tran: time = 37.72 ns    (37.7 %), step = 263.5 ps     (264 m%)
   tran: time = 42.52 ns    (42.5 %), step = 24.46 ps    (24.5 m%)
   tran: time = 47.59 ns    (47.6 %), step = 382.2 ps     (382 m%)
   tran: time = 52.52 ns    (52.5 %), step = 36.47 ps    (36.5 m%)
   tran: time = 57.72 ns    (57.7 %), step = 263.5 ps     (264 m%)
   tran: time = 62.52 ns    (62.5 %), step = 24.46 ps    (24.5 m%)
   tran: time = 67.59 ns    (67.6 %), step = 382.2 ps     (382 m%)
   tran: time = 72.52 ns    (72.5 %), step = 36.47 ps    (36.5 m%)
   tran: time = 77.72 ns    (77.7 %), step = 263.5 ps     (264 m%)
   tran: time = 82.52 ns    (82.5 %), step = 24.46 ps    (24.5 m%)
   tran: time = 87.59 ns    (87.6 %), step = 382.2 ps     (382 m%)
   tran: time = 92.52 ns    (92.5 %), step = 36.47 ps    (36.5 m%)
   tran: time = 97.72 ns    (97.7 %), step = 263.5 ps     (264 m%)
Number of accepted tran steps =             3590
Initial condition solution time: CPU = 29.996 ms, elapsed = 29.5751 ms.
Intrinsic tran analysis time:    CPU = 8.5757 s, elapsed = 8.58898 s.
finalTimeOP: writing operating point information to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
subckts: writing subcircuits to rawfile.
Aggregate audit (11:38:04 AM, Fri Oct 10, 2014):
Time used: CPU = 9.22 s, elapsed = 12.6 s, util. = 73.3%.
Time spent in licensing: elapsed = 52.8 ms.
Peak memory used = 65 Mbytes.
Simulation started at: 11:37:52 AM, Fri Oct 10, 2014, ended at: 11:38:04 AM, Fri Oct 10, 2014, with elapsed time (wall clock): 12.6 s.
spectre completes with 995 errors, 5 warnings, and 14 notices.
boe
Re: Spectre_simulator : Post layout verification problem
Reply #1 - Oct 13th, 2014, 3:28am
ghegde wrote on Oct 9th, 2014, 9:57pm:
Thanks in advance,
We need more info to help you.
   start = 0 s
   outputstart = 0 s
   stop = 100 ns
   step = 100 ps
   maxstep = 1 ns
   ic = all
   useprevic = no
   skipdc = no
   reltol = 10e-06
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   method = gear2only
   lteratio = 10
   relref = alllocal
   cmin = 0 F
   gmin = 1 pS
              save 1
Here the simulation runs.
- B O E
Reply #2 - Oct 17th, 2014, 6:39am
ghegde,
 `leff' is less than zero means that the effective channel length
of a device is less than zero. The most likely cause is either you
are using too short a gate length or you are using a low voltage
device in a high voltage domain. Remember that channel length
is modulated by drain depletion region.
ghegde
Singapore
Reply #3 - Oct 21st, 2014, 2:30am
boe wrote on Oct 13th, 2014, 3:28am:
Thanks in advance,
   start = 0 s
   outputstart = 0 s
   stop = 100 ns
   step = 100 ps
   maxstep = 1 ns
   ic = all
   useprevic = no
   skipdc = no
   reltol = 10e-06
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   method = gear2only
   lteratio = 10
   relref = alllocal
   cmin = 0 F
   gmin = 1 pS
              save 1
- B O E
Hi Boe,
         Thanks for the reply.May I know what additional information I can provide to better understand this problem?Also did you mean that simulation completed successfully?
ghegde
Singapore
Reply #4 - Oct 21st, 2014, 2:36am
sheldon wrote on Oct 17th, 2014, 6:39am:
ghegde,
Thanks Seldon for the help.
The channel length of the device were 0.35um. Can you please elaborate a little your statement "you are using a low voltage device in a high voltage domain" for my better understanding?
Thanks again,
Reply #5 - Dec 11th, 2014, 7:06am
ghegde,
   If a high voltage is applied to a low voltage device, then the depletion  region of the drain can reduce the channel length and
potentially cause an "effective" negative channel length.
ghegde
Singapore
Reply #6 - Dec 11th, 2014, 7:14am
sheldon wrote on Dec 11th, 2014, 7:06am:
ghegde,
Thanks  Sheldon.
