Aug 30th, 2024, 1:15am
Redundancy vs Calibration (Read 5201 times)
Sx_cut
Dresden, Germany
Oct 29th, 2014, 7:35am
I am working on a 12 bit segmented SAR ADC. I need to if know calibration is used to cater for the device mismatch and process variations of DAC array while redundancy is used to recover from wrong comparator errors ? Can redundancy also be used for mitigating ADC errors coming from device mismatch?
carlgrace
Berkeley, CA
Re: Redundancy vs Calibration
Reply #1 - Oct 29th, 2014, 2:56pm
Hello Lissa,
Redundancy is a way of making the ADC resistant to errors.  It is a distinct concept from calibration.  Either one (or often both) can be used to desensitize the circuit to device mismatch and process variation.  Whether you use one or both depends on your specs and what errors you expect.
Redundancy is a hot topic in SAR design right now.  You can get away without calibration in some cases if you add additional redundant cycles.  You can think of this as a "time-domain" version of the well know hardware redundancy in pipelined ADCs.  It is harder to get away without calibration if you add redundant hardware because then your radix can change and you must know the radix precisely (to the 1/2 lsb level ,at least).
Here is an excellent review paper that discusses these concepts and gives a lot of good references for you to read.
http://www.eurasip.org/Proceedings/Ext/SampTA2013/papers/p556-murmann.pdf
Sx_cut
Dresden, Germany
Reply #2 - Oct 30th, 2014, 12:40am
Thanks Carlgrace. I have read certain papers on SAR ADCs with redundancy but one thing that I am not able to figure out is how people decide where to implement redundancy (I mean for 12 bit ADC, some one may go with a redundant bit after 4 bits than another one after 4 bits......). During initial cycles of SAR conversion the comparator sees a large differential input (typically) which must narrow down to zero (ideally) by the end of SAR scheme. Should we not deduce from here that ADC is more likely to generate errors during the LSB cycles of SAR scheme and so redundancy must be implemented in the LSB bits instead of MSB bits?
RobG
Bozeman, MT
Reply #3 - Oct 31st, 2014, 8:01am
I'm working that problem right now with a 12b. The ADC is much easier to calibrate digitally if you use redundancy since you can force the ADC to take two paths and then apply digital correction to make the two paths give the same result.
Redundancy is awesome Cheesy. For example, doing a 12 bit conversion with 15 comparisons can (if done correctly) allow very large errors for all but the last two comparisons. Therefore,
1) Your reference doesn't have to settle completely,
2) Your comparator can be very noisy and simple (i.e. fast latch), and
3) Offset differences between stages isn't important so you can use a fast latch for each of the stage
But remember these don't apply to your last two comparisons - they need a low noise comparator.
In addition, cap mismatches can be on the order of 25%, but they do have to be accounted for digitally, whereas the other errors require no digital correction.
Unfortunately, I haven't found many detailed papers to help me. This MIT Thesis was helpful, but I didn't think he did a good job in implementing his own teachings, especially his weightings. It has a good bibliography. Lui, "A 12-bit 45-MS/s, 3-mW Redundant...", JSSC, Nov 2011 was also a good read.
I had to derive my own calibration procedure since I couldn't find a published one, but the papers describe in general terms how it needs to be done.
RobG
Bozeman, MT
Reply #4 - Oct 31st, 2014, 8:04am
Sx_cut wrote on Oct 30th, 2014, 12:40am:
Not really, take a look at the MIT Thesis I just referenced to see how redundancy is used.
RobG
Bozeman, MT
Reply #5 - Oct 31st, 2014, 8:05am
RobG wrote on Oct 31st, 2014, 8:01am:
Unfortunately, I haven't found many detailed papers to help me. This MIT Thesis was helpful, but I didn't think he did a good job in implementing his own teachings, especially his weightings. Lui, "A 12-bit 45-MS/s, 3-mW Redundant...", JSSC, Nov 2011 was also a good read. Be sure and look at their references.
