May 5th, 2024, 7:33am
how to do dynamic comparator offset simulation? (Read 4241 times)
A Kumar R
India
Dec 02nd, 2014, 5:19am
Because we can't perform a DC simulation on latch-based comparators, what is the way to measure offset?
Rite now, i am sweeping one of the input as slowly as possible. This is so to have slight changes from one clock edge to the next so that we can predict offset accurately. And then see where it trips.
is this correct?
Anil Reddy
raja.cedt
Re: how to do dynamic comparator offset simulation?
Reply #1 - Dec 2nd, 2014, 6:33am
works  fine in case if you don't have any hysteresis and offset accuracy depends on your ramp rate.
For accurate method go here..
http://www.designers-guide.org/Analysis/comparator.pdf
Raj.
hiSkill_11
Reply #2 - Sep 8th, 2015, 11:41pm
raja.cedt wrote on Dec 2nd, 2014, 6:33am:
Raj.
Another question following this since they are related.
How can we evaluate noise for comparators used in high accuracy SAR ADC such 12b? How to setup and what's the integration bandwidth?
Thanks.
Reply #3 - Oct 29th, 2016, 5:58am
hiSkill,
    There is a paper you can look at,
Method from “A Low-Noise Self-Calibrating Dynamic Comparator for
High-Speed ADCs”, Masaya Miyahara, Yusuke Asada, Daehwa Paik and
Akira Matsuzawa, A-SSCC 2008. IEEE Asian Solid-State Circuits
Conference, 2008, pg. 269-272 (used Spectre transient noise)
It discusses the transient noise based method for calculating dynamic
comparator noise. If you want information on using PSS/PNOISE for
dynamic comparator noise, contact your Cadence AE.
NOTE:
1) Using PNOISE does mean that the noise summary is available
2) The PSS based approach can be extended to calculation of the
    sampling aperture.
