Jul 25th, 2024, 7:34pm
Pages: 1 2
Distortion components in SAR ADC output spectrum.Advice/Help needed (Read 3260 times)
Re: Distortion components in SAR ADC output spectrum.Advice/Help needed
Reply #15 - Feb 23rd, 2015, 8:11pm
Hi DanielLam,
The first structure you mentioned is talked in this thread.  :)
DanielLam wrote on Dec 16th, 2014, 10:25pm:
When you say split cap, do you mean you use an attenuation capacitor? Or are you splitting capacitors into 2 halves to save power (no attenuation capacitor)?
If it is the attenuation capacitor, you should see distortion reduced by increasing the unit cap size (eg 10 fF to 100 fF). This leads me to think that you are splitting caps into two halves.
If it is the latter, try different types of caps to see if there is a difference. I have a feeling it might be the voltage coefficient.
Yawei
Pages: 1 2
