May 3rd, 2024, 10:30pm
Pages: 1 2
Any advice for PSS converge? (Read 16163 times)
Frank Wiedmann
Munich, Germany
Re: Any advice for PSS converge?
Reply #15 - Mar 19th, 2015, 5:45am
Did you take a look at my earlier reply (#3)?
sharpmental
Reply #16 - Mar 23rd, 2015, 10:09pm
Hi Frank,
Yes, I did. I think that ticket means: "the input and output shall have a smooth relation".
I reviewed my code, I "feel" they are, but can not be 100% sure due to many switching behavior of DC-DC itself.
However, i think the "smooth behavior" requirement is conditional because I have done switching cap amp and chopper amp model. The way I describe it is obviously not "smooth" but they work on PSS/PSTB.
Reply #17 - Mar 23rd, 2015, 10:40pm
To debug it, you need to treat it as a simple signal tracing problem. You inject a signal and see where it is blocked. If you show us the module that blocks the signal, we might be able to help.
sharpmental
Reply #18 - Mar 24th, 2015, 7:10pm
I have to find a new job so i am not in a mood to work these days.  >:(
Here is the model I build.
This picture show my top level testbench.
The inductor is 22uH and the load cap is 20~47uF.
The compensation use a 10nF external cap on the output of the gm style EA.
sharpmental
Reply #19 - Mar 24th, 2015, 7:11pm
And, the controller include these blocks:
sharpmental
Reply #20 - Mar 24th, 2015, 7:12pm
So this is a simple Voltage mode control.
And, here is the pack of all verilogA code.
it would be good to hear your advise so I can make this work.
Thanks.
Pages: 1 2
