Note that this last reply was a bit misleading. Verilog-AMS and SystemVerilog can coexist. You should however use the file suffix to determine whether it is compiling Verilog-AMS or SystemVerilog rather than forcing it via a command line option (which would indeed cause a problem). It's not clear whether that was the problem the original poster faced - it was an elderly posting...
Andrew
