Jul 20th, 2024, 8:26pm
Verilog AMS co simulation with SV (Read 5047 times)
ranjang
india
Feb 24th, 2015, 4:40am
I wanted to simulate the verilog ams code with testbench as SV/UVM.
I face some problem but when I simulate with spice and SV its working fine.
Do I need to write amsd{
block for running verilog -AMS with SV.
I am using cadence simulator and running the simulation from command line.
GAURAV
AMS_ei
Re: Verilog AMS co simulation with SV
Reply #1 - Jan 18th, 2017, 8:04am
sv and ams cannot co-exist. You have to remove -sv switch from the irun option if you have used it.
Then it should be compiling fine.
Thank you.
Kind regards,
Reply #2 - Jan 20th, 2017, 9:21am
Note that this last reply was a bit misleading. Verilog-AMS and SystemVerilog can coexist. You should however use the file suffix to determine whether it is compiling Verilog-AMS or SystemVerilog rather than forcing it via a command line option (which would indeed cause a problem). It's not clear whether that was the problem the original poster faced - it was an elderly posting...
Andrew
