Aug 26th, 2024, 3:20pm
How much of the charge pump current should be used for a PLL (Read 3283 times)
zczc999
Mar 27th, 2015, 4:48am
I am new to PLL design. I have a question that which level of charge pump current is suitable for a pll.
I know the current should meet the requirement of bandwidth, damping, etc. But which order of magnitude is preferable, say 10uA, 20uA, 50uA, or 100uA, considering matching, noise. Now I am using a 15uA charge pump, I don't know if it is too small.
And the current has glitches at the edge of switching signals. The glitch is about 30uA. Will this has big affect on phase noise?
BTW, to eliminate the deadzone of PFD, a delay will insert at the reset path. Usually how much delay is added? I think the smaller the better, as long as the pulse can turn on/off the switches, so I am using about 200ps. Am I right?
Re: How much of the charge pump current should be used for a PLL
Reply #1 - Mar 27th, 2015, 2:58pm
The charge pump current directly affects the gain of the loop, and hence its stability. Among any other constraints, the charge pump current is chosen to satisfy stability requirements.
Reply #2 - Mar 27th, 2015, 8:53pm
Charge pump current is interactively traded off against loop filter parameters. Higher currents mean bigger loop filter capacitors.
Now, what happens, is that the charge pump current can be scaled so that the charge injection of the current steering switches is insignificant in comparison to the charge pump current.
weber8722
Reply #3 - Apr 21st, 2015, 11:43pm
all your questions are good questions! Best orient on a working design. Higher Icharge allows bigger C for same time-constant and thus lower noise. But if your osc is not low-noise too (like a simple ring-osc instead of LC osc with high-Q elements), then an over-design in CP makes little sense.
The first decision is probably also wether C of PLL loop filter is on-chip or off-chip. For on-chip you are typically anyway quite limited.
Collect all your specs, and discuss them with an expert + compare them to well-documented commercial PLL designs.
At CP output you usually see the wanted pulse current but together with a spike which often comes from Cgd of switching transistors. Often it matters not much, but adding a cascode can help - also for more constant output current vs Vout.
Optimize you CP + PFD togther over PVT corners + MC, then you should see how much margin is needed, better a bit more.
Bye Stephan
