Apr 28th, 2024, 1:14pm
How does a behavior sine wave to drive a logic gate? (Read 3272 times)
ruwan2
Apr 13th, 2015, 9:55pm
After some testing, I can use a logic gate to drive a resistor with verilog-AMS. When I try to drive a logic gate with a sine behavior wave code:
`include "disciplines.vams"
`include "constants.vams"
module sinVarFreq(p, n);
    inout	p, n;
    electrical p, n;
    parameter real freq  = 1.0e2;
    parameter real coeff = 1.0;
    real tempr;
    analog begin
	  V(p,n) <+ 15.0*sin(`M_TWO_PI * freq * (sin(`M_TWO_PI * coeff * $abstime) + 1.0) * $abstime);
It looks like the logic input seen as a hiz in the picture:
I have a doubt about it on the behavior sine wave unit. Although it is larger than 10, whether it is in Volt? In this EDA tool, I have set the interface model:
.model itf y level=itf delay=1n vin1x=2.4 vinx0=2.4 vin0x=2.6 vinx1=2.6
What is wrong will result in such a problem (logic does not react to a varying analog input signal?
Re: How does a behavior sine wave to drive a logic gate?
Reply #1 - May 4th, 2015, 6:55am
ruwan2 wrote on Apr 13th, 2015, 9:55pm:
Since you have declared the ports as "electrical p, n;" I would expect that the disciplines.vams will show you that the units of the potential for that discipline are, indeed, Volts.
I don't know what your .model itf does; I'm not familiar with an element that has parameters vinx0, etc.
