May 5th, 2024, 12:29pm
stb break loop location (Read 2082 times)
newic
May 19th, 2015, 12:23am
hi
for the STB analysis in the circuit below, I have defined the 3 location that we can break the loop (break1, break2 & break3). All these gave me the same gain/phase plot. However when i use AC method (non-STB), it give different results in break1 & break3. The break2 shows the same result as in the STB. The STB can break in any locations as long as the loop is break?
can someone explain why?
the ac method is the one to break the loop by big R-C or L-C.
newic
Re: stb break loop location
Reply #1 - May 19th, 2015, 12:25am
newic
Reply #2 - May 19th, 2015, 12:25am
newic
Reply #3 - May 19th, 2015, 12:26am
Reply #4 - May 19th, 2015, 7:35am
The "AC method" as you call it is wrong, don't use it.
newic
Reply #5 - May 19th, 2015, 5:56pm
what shall i called for those using non-STB method?
one more question, according to Jacob Baker famous analog book, it uses simple RC to break the loop. Furthermore it inject ac at the non-feedback path.  The result should be similar to STB method if really big RC is used and include the loading after the breaking point right. any comment?
i think most ppl using this method due to his book since it is so famous.
any comment?
Reply #6 - May 20th, 2015, 8:54pm
It is not accurate. Do not use it.
Reply #7 - Jul 4th, 2015, 7:55pm
Hi newic,
Probably in your case the inverting input of the amplifier has minor effect on the loop gain. So gain and phase response of AC analysis is similar with that of STB analysis. However, even the inverting input amplifier may affect the bandwidth for some wide-band application. Do NOT use AC analysis instead of STB.
Yawei
newic
Reply #8 - Jul 27th, 2015, 12:43am
how to simulate stb in hspice?
Frank Wiedmann
Munich, Germany
Reply #9 - Jul 28th, 2015, 1:35am
Search the manual for .LSTB (Loop Stability Analysis).
