Apr 30th, 2024, 11:14am
Problem with wreal simulation - RNM Real Number Modeling (Read 7483 times)
Zorro
Jun 03rd, 2015, 8:18am
Hi everybody,
here is a description of the problem I have.
I hope someone can help with a suggestion.
It is important to mention that am relatively new to RNM/wreal modeling (RNM=Real Number Modeling)
This is only for testing purposes but I am seeing some unexpected behavior.
I have two different versions of a stimuli block:
- one version uses electrical for inout pin vdd
- the other version uses wreal for inout pin vdd.
See picture 1.
Here is the code of both stimuli blocks and the table file:
VERSION USING ELECTRICAL FOR INOUT PIN vdd
`timescale 1ns/1ps
`include "constants.vams"
`include "disciplines.vams"
module dut2_stim_vams (vcontrol ,vdd, vss, reset, ana_out1, ana_out2, ana_out3, ana_out4, dig_out1, dig_out2, dig_out3, dig_out4);
     // Pin Directions
     output      vcontrol, reset, ana_out1, ana_out2, ana_out3, ana_out4, dig_out1, dig_out2, dig_out3, dig_out4;
     inout      vdd, vss;
     // Pin Types
     wreal            ana_out1, ana_out2, ana_out3, ana_out4;
     logic            dig_out1, dig_out2, dig_out3, dig_out4;
     logic            reset;
     electrical      vcontrol ,vdd, vss;
     // Variable Declarations
     real        vss_reg;
       real        simtime;
       real        vcontrol_reg;
       real      vdd_reg;
       reg            reset_reg;
     // Core
     initial begin
           vss_reg = 0;
           vcontrol_reg= 0;
           vdd_reg= 0;
           reset_reg = 1;
           #250 reset_reg = 0;
     always begin
           #1
           vcontrol_reg = $table_model($abstime,"vcontrol_stim.vat","1LL") ;
           vdd_reg = $table_model($abstime,"vdd_stim.vat","1LL") ;
           //vdd_reg = $table_model($abstime,"vcontrol_stim.vat","1LL") ;
     //always begin
           //#1000 $finish;
       //end
     analog begin
           V(vdd)      <+ vdd_reg;
           V(vcontrol) <+ vcontrol_reg;
           V(vss)      <+ vss_reg;
       assign reset = reset_reg;
VERSION USING WREAL FOR INOUT PIN vdd
`timescale 1ns/1ps
     // Pin Directions
     inout      vdd, vss;
     // Pin Types
     logic            reset;
     //electrical      vcontrol ,vdd, vss;
     wreal            vcontrol ,vdd, vss;
     real        vss_reg;
       real        simtime;
     real        vcontrol_reg;
     real      vdd_reg;
       reg            reset_reg;
     // Core
     initial begin
           vss_reg = 0;
           vcontrol_reg= 0;
           vdd_reg= 0;
           reset_reg = 1;
           #250 reset_reg = 0;
     always begin
           #1
     //always begin
           //#1000 $finish;
       //end
//      analog begin
     //      V(vdd)      <+ vdd_reg;
     //      V(vcontrol) <+ vcontrol_reg;
     //      V(vss)      <+ vss_reg;
 //      end
     assign vdd                  = vdd_reg;
     assign vcontrol      = vcontrol_reg;
     assign vss                  = vss_reg;
vdd_stim.vat
# time      voltage
0              2.5
1u              2.4
2u              2.1
3u              2.0
4u            2.5
5u              2.0
If a simulate the stimuli blocks alone (without connecting them to any other block) I get the expected behaviors. See picture 2.
Now if I connect a DUT (simple resistor voltage dividers which divide the input voltage by 2 and by 4) the electrical signal behaves correctly (as before) but the wreal signal behaves very strange, its value decreases. See pictures 3, 4, 5 and 6 below.
Any idea what could be causing this wrong behavior in the wreal vdd signal?
Zorro
Re: Problem with wreal simulation - RNM Real Number Modeling
Reply #1 - Jun 3rd, 2015, 8:20am
Picture 2
Zorro
Reply #2 - Jun 3rd, 2015, 8:20am
Picture 3
Zorro
Reply #3 - Jun 3rd, 2015, 8:20am
Picture 4
Zorro
Reply #4 - Jun 3rd, 2015, 8:21am
Picture 5
Zorro
Reply #5 - Jun 3rd, 2015, 8:21am
Picture 6
boe
Reply #6 - Jun 3rd, 2015, 10:04am
Zorro,
a resistor needs an "electrical", if you connect a "wreal" to it, a connect module (CM) is automatically inserted, which translates between "wreal" and "electrical".
A CM for translating from wreal to electrical typically uses a staircase mechanism and has an output impedance.
- B O E
PS: for convergence reasons, you should use a transition filter for an electrical pwl signal.
Zorro
Reply #7 - Jun 4th, 2015, 2:36am
Hi boe,
thanks for your reply. Below my comments and maybe you can add an extra comment to them.
1.
That means to compare the wreal model against the schematic (in the same testbench) the best is to use electrical pins for the analog stimuli signal rather than  using wreal pins for the analog stimuli signal.
Doing so we avoid the insertion of ConnectModules for the connection wreal-->spectre(I mean the resistor inside the DUT) and we don't have the effects of the CM's output resistance.
2.
If we do as stated in 1., .... what about the ConnectModule for the connection electrical-->wreal ??? the CM's output resistance could also play a role here, or????
3.
Your PS. indicates the use of electrical pins for the analog stimuli signal rather than  using wreal pins for the analog stimuli signal.
In this case there was no convergence problem using the electrical pin, but for complex DUTs (or in general) you recommend to do this:
V(vdd)      <+ transition(vdd_reg, td, tf, tf);
correct?
Thank you for your advices.
boe
Reply #8 - Jun 4th, 2015, 8:22am
Zorro wrote on Jun 4th, 2015, 2:36am:
1.
Usually, yes.
Quote:
2.
No, because wreal only represents voltage, there is no output resistance. (NB: It is also time discrete.)
Quote:
3.
correct?
Yes.
- B O E
Zorro
Reply #9 - Jun 5th, 2015, 2:21am
thank you boe, it is clear to me now what is the best way to proceed.
I wanted to do a check, so I did this:
For this example the DUT internal resitance is:
Rdut = (1k+1k) // (3k+1k) = 2k // 4k = 1.333333k
From the pictures I can see that I get 2.15348V (vout) instead of the expected 2.5V (vin) at time 4us.
so:
vin * Rdut / (Rcm + Rdut) = vout
Rcm = Rdut * (vin - vout) / vout = 1.333333k * (2.5 - 2.15348) / 2.15348 ~ 214.5488 ohms
from the connect rules that I am using I found this:
connect R2E_2 #(.vsup(`Vsup), .vdelta(`Vdelta), .tr(`Tr_delta), .tf(`Tr_delta), .rout(`Rlo));
`define Vsup  1.8
`define Vdelta      `Vsup/64
`define Tr    0.2n
`define Tr_delta    `Tr/20
`define Rlo   200
which approximately matches the calculation that I did for Rlo.
