May 3rd, 2024, 7:32pm
Low Frequency Oscillation in PLL Control Voltage (Read 4858 times)
Faye
Jun 16th, 2015, 11:04am
Hi all, I am designing a PLL at 1GHz with output tracking the input (no divider). I am using a PFD/CP with RC//C loop filter, and my VCO is a delay-line type ring oscillator. I chose a phase margin=60 degrees, damping factor zeta=1, the loop bandwidth=25MHz, and the natural frequency=10MHz.
When I went to Cadence transistor-level simulation, I could always see when the control voltage approaches the voltage required for locking (close to 0.7V in my case), it always has a low frequency ripple on it. I've attached the settling behavior of the control voltage. The ripple is about 20MHz and has a peak-peak amplitude of about 40mV.
I've tried to replace the VCO with an ideal VCO and the loop locked quietly with only high frequency ripple (frequency same as the reference) of about 1mV, so I assume the problem comes from my VCO. But my VCO works good individually as a block with a good linearity in the range of interest. I also tried to add two vcvs as buffers before and after the VCO in the PLL, but that didn't help.
I don't quite understand where the low frequency (20MHz) ripple comes from and how to solve the problem. I will appreciate if you can give any inputs or suggestions!
Faye
raja.cedt
Re: Low Frequency Oscillation in PLL Control Voltage
Reply #1 - Jun 16th, 2015, 2:39pm
Looks like your bandwidth is bit high or some problem with your loop filter parameters. Please check once. What is your reference frequency,KVCO,ICP,cfilter.
Raj.
Faye
Reply #2 - Jun 17th, 2015, 8:28am
Hi Raj,
The reference frequency is 1GHz, Kvco is pretty high at about 1.6GHz*2pi/V since it is a ring oscillator. Icp is 50uA and R=1.5K, C1=20pF, C2=2pF. The bandwidth is about 25MHz based on the parameters.
Faye
Reply #3 - Jun 17th, 2015, 1:50pm
OK, so you oscillation is close to your loop BW - there is probably a message in that.
I would go through your gain-phase numbers again and see if you got phase margin, or a block parameter that is not correct.
wave
Reply #4 - Jun 17th, 2015, 4:06pm
Faye wrote on Jun 17th, 2015, 8:28am:
Hi Raj,
Faye
Good grief.
First, look at your architecture.
Do you really want a DLL instead of a PLL?
If you *really* want a PLL with PD/CP/LF, then there are some well known ratios of Refclk to LF bandwidth, which I'm pretty sure are being violated here.
Last, think about your KVCO.
You didn't spec your supply, but say it's 1V.  You don't want to operate near the rails.  You didn't spec your pull range, but say it's +/- 100 MHz.  So you'd want a little more than 200 MHz / V, about a factor of 5-10 less than you have now.  Excess gain will pick up noises.
Wave
Cool
AZADBAKHT
Reply #5 - Jul 5th, 2015, 2:34pm
sir wave was right.
in the first time you should check out your VCO, because of for having best spur at the output LO, the KVCO must be about 100-200-MHz. additionally, the PFD/CP can't offer good dead-zone under steady-state with this Fref!! (Fref must be about less than of 100-MHz), so you should uses the divider in the feedback path(in the first time you can uses the ideal Flip-Flop in ahdlLib library). at the end, you should chose B.W under 100-KHz (this issue is very important).
for speed up to your design you can refer this website and calculate your LPF as online!
Web address:
 http://www.circuitsage.com/pll/pll.htm
(note that if you want to do transistor level simulation, you need to about >10 hour for done simulation!!)
i hope to be able to do your help
Azadbakht
View Profile milad12333   IP Logged
