Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 11
th
, 2024, 11:43pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› how loop delay in charge pump pll will affect its loop stability
Previous topic
Next topic
how loop delay in charge pump pll will affect its loop stability (Read 3592 times)
rfic
San Diego, CA
Jul 13
th
, 2015, 9:52pm
if i insert a fix loop delay inside CPPLL, how the loop stability suppose to change?
for example, my vco has 8 phases, if i choose phase <7> instead of phase <0>, is loop stability same?
thanks
IP Logged
Re: how loop delay in charge pump pll will affect its loop stability
Reply #1 -
Jul 16
th
, 2015, 4:03pm
please clarify your question - a fixed delay on a PLL removes phase margin from the control system, but you mention tapping off of a different connection on a ring oscillator which is something different -
IP Logged
rfic
San Diego, CA
Reply #2 -
Jul 18
th
, 2015, 11:41am
loose-electron wrote
on Jul 16
th
, 2015, 4:03pm:
i did mean fix delay, and i think fix delay will degrades PM as well; if this is true, then i expect using phase 7 of ring osc suppose to have less PM compared to using phase 0 of that ring osc as feedback clock -- is this derivation correct?
IP Logged
Reply #3 -
Jul 19
th
, 2015, 1:41pm
fixed delays can be introduced at several places in a PLL, in some locations it introduces a phase relationship shift and in other places it changes the phase margin
define what you are doing
IP Logged
baohulu
china
Reply #4 -
Jul 23
rd
, 2015, 11:44pm
it seems phase7 and phase8 leave the same phase margin
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
