May 5th, 2024, 10:10am
PLL Design (Read 4442 times)
Sushanthhegde3
PLL Design
Jul 19th, 2015, 8:58pm
What is coarse and fine integration in PLL Design?
Re: PLL Design
Reply #1 - Jul 20th, 2015, 10:53pm
probably two different current setting for the charge pump.
Fast acquire PLL's sometime use a structure where the charge pump goes into high current mode when starting lock up, and then drops to lower current as the loop gets closer to phase lock.
Allows for a faster frequency acquisition and phase pull in process.
Sushanthhegde3
Re: PLL Design
Reply #2 - Jul 20th, 2015, 11:07pm
Thank you for the reply.
If my loop filter has second order transfer function,then how can I know when is coarse integration and fine integration is taking place?
Could you please point me to the architecture you are referring to?
Thank you.
Re: PLL Design
Reply #3 - Jul 21st, 2015, 6:55pm
I have used the described architecture for timing clock acquisition. Is it in a paper someplace? I have no idea.
What I did (it was a disk drive read channel) was go high current for the first 10 cycles of the header preamble and then flip to lower current. This got you closer on frequency very quickly.
rfmagic
Re: PLL Design
Reply #4 - Jul 23rd, 2015, 11:25am
In the same direction as Loose-Electron has pointed out, it may also be the case where the loop BW has 2 modes i.e. high BW mode for fast acquisition and low BW mode for normal operation for optimal PN
Sushanthhegde3
Re: PLL Design
Reply #5 - Jul 24th, 2015, 3:05am
Thank you for the explaination. I have another query.The bang bang phase detectors used in ADPLL can measure the phase of early or late signals.If the reference is leading then early will be at logic 1 and if the feedback is leading then the late signal will be at logic 1.In some literatures I came to know that the BBPD can measure the frequency difference too.Could you plz help me to understand?
Thanks in Advance Smiley
Re: PLL Design
Reply #6 - Jul 27th, 2015, 10:31am
Sushanthhegde3 wrote on Jul 24th, 2015, 3:05am:
THis is the difference between a
Phase Detector (PD)
and a
Phase-Frequency Detector (PFD)
A PFD will tell the PLL to go up or down until the frequency is the same and then just adjust for phase.
A PD will give a mixture of up-down information depending on the instant phase relationship of the two signals.
I am sure there is some information out there on this. Look for timing diagrams of the PFD and PD to see a comparison.
