michdundee78
Hi all, I'm trying to model an OTA with the following parameters: - gm - output resistance - compensation cap - max output current - limited output voltage range
how to properly model its frequency response and how to limit its output voltage?
If someone needs the code I have written till here I can share it.
thank you in advance.
cheers
