Jul 16th, 2024, 11:29am
OTA model help (Read 2072 times)
michdundee78
OTA model help
Aug 07th, 2015, 10:47pm
I'm trying to model an OTA with the following parameters:
- gm
- output resistance
- compensation cap
- max output current
- limited output voltage range
how to properly model its frequency response and how to limit its output voltage?
If someone needs the code I have written till here I can share it.
thank you in advance.
cheers
