May 3rd, 2024, 10:31am
Parasitic resistors problem of NMOS switch in pnoise simulation in simple S&H (Read 1934 times)
OmerNuz
Aug 18th, 2015, 4:15am
I have a problem with parasitic noise sources of rs & rd of NMOS switch in simulating the simple sample and hold circuit noise with pnoise. When I look at the noise sources from noise summary, I see that in addition to id noise of NMOS switch, there are two other noise sources rs & rd.
I saw that rs & rd noise changes with the pulse width of the clock but I could not find the reason for that noise? In some simulations, these are the dominant noise sources.
What is the reason for that noise or has anyone encountered this problem before?
Re: Parasitic resistors problem of NMOS switch in pnoise simulation in simple S&H
Reply #1 - Aug 18th, 2015, 3:59pm
rs and rd are parasitic resistors in series with the source and the drain. The noise you are seeing is the thermal noise they produce.
