Apr 28th, 2024, 10:21pm
Reducing PA distortion (Read 2336 times)
analogy
Aug 31st, 2015, 8:11pm
Hypothetically one can reduce PA distortion either via negative feedback or using a filter between PA and antenna (speculating the latter half).
Which method is commonly used to reduce PA distortion and why ?
Thanks.
aaron_do
Re: Reducing PA distortion
Reply #1 - Sep 1st, 2015, 5:25pm
typically neither method is used.
Although there are negative feedback based power amplifiers, they're not very common because (also speculating) they represent a heck of a design challenge. In order to optimize performance, power amplifiers need to operate close to their stability and reliability limits. So you can imagine that adding a path from output to input could lead to problems if the circuit and layout modeling is inadequate.
Filtering only works if there is only one frequency channel being used as so far there aren't any good tunable RF filters on the market (good research project?). That rules out Wifi, Mobile and Bluetooth. Also, filtering removes the sidebands, but doesn't improve SNR, so its use is limited.
The most common way to reduce PA distortion is simply to back-off the PA (i.e. transmit at a lower power than it is capable of). But there are plenty of methods such as pre-distortion, cartesian feedback etc which have applications.
regards,
Aaron
Reply #2 - Sep 2nd, 2015, 12:55pm
frequently it is a multitude of methods, and depends on the PA architecture. Filters, feedback, predistortion, optimize bias point with power level, and others. Research time. IEEE MTT and IEEE JSSC
