neoflash
![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif)
![](http://avatar.elektroda.net/gallery/00fun/download.php-1072.gif)
Mixed-Signal Designer
I have a question about simulating the noise of a S/H circuit.
The method I am using right now is to simulate noise in sample and hold phase separately.
First, I put it in sample mode and simulate the noise over the sampling capacitor (CS) and hold capacitor (CH).
I used HSPICE .NOISE and integrated over entire frequency band. The result seems to match KT/C closely.
However, later I added a switch as noted in the diagram (represented by the red resistor Rp). If I use the noise voltage across capacitor + Rp, the noise is much higher. Rp contributes a lot of noise at higher frequency.
And I think I should use the noise voltage across the capacitor Cs only since it is the charge noise that we care.
Shall I include Rp in sample phase noise integration? Thanks!
