May 2nd, 2024, 4:07am
PSRR cadence (Read 1399 times)
pekachoo007
PSRR cadence
Sep 22nd, 2015, 11:07am
how to find PSRR of a voltage reference circuit in cadence, which has one input and two outputs.
Re: PSRR cadence
Reply #1 - Sep 23rd, 2015, 9:14pm
Is it two outputs like V1=1.25V and V2=2.5V or a differential output?
pekachoo007
Re: PSRR cadence
Reply #2 - Sep 25th, 2015, 9:57am
2 outputs 0.2 & 2 V.
Re: PSRR cadence
Reply #3 - Sep 28th, 2015, 9:17pm
Typically I use transfer function analysis for PSRR. In your
case, you run transfer function analysis twice, once for each
output. The advantage of transfer function analysis is that you
can use one analysis for VDD PSRR, GND PSRR, and CMRR,
by properly defining the sources in the testbench.
pekachoo007
Re: PSRR cadence
Reply #4 - Sep 30th, 2015, 3:28am
is transfer function analysis is xf analysis? what do you mean by properly defining the sources in the testbench.
Re: PSRR cadence
Reply #5 - Oct 5th, 2015, 7:56pm
You will need to include a voltage supply between gnd! and the
DUT, in order to capture, VSS PSRR. For the input, use the
ideal_balun and define differential and common mode input
sources.
