May 4th, 2024, 12:22pm
Clock frequency to voltage converter (Read 2270 times)
Rosh
Oct 05th, 2015, 6:46pm
Hello everyone,
I have a clock signal that varies from 10Mhz- 100Mhz and I need to generate a voltage proportional to the frequency as it varies in step size of 50kHz.
Is there any way to accomplish this? Would a simple RC high  pass filter solve the problem?  :(
DanielLam
Re: Clock frequency to voltage converter
Reply #1 - Oct 6th, 2015, 12:14am
How linear does it need to be?
I think you could use an XOR gate and lowpass filter the output to get an average voltage.
The two inputs of the XOR are 1) your clock signal and 2) a delayed version of your clock signal.
This delayed version would have a delay proportional to the frequency. To do this, I would stick the clock signal through a lowpass or a highpass filter. This will provide a phase shift proportional to the frequency. Note, I am assuming the voltages are large enough such that the XOR can still process the delayed version correctly.
Reply #2 - Oct 9th, 2015, 5:31pm
http://www.digikey.com/product-search/en/integrated-circuits-ics/pmic-v-f-and-f-...
Divide your signal down digitally before plugging into a FVC.
Other methods: count your signal over fixed period of time. Put numeric result into a DAC.
