sunmus
Hi, I am trying to write a phase noise model of an integer divider. The input and output ports are of type phase and is accessed using Theta. For example, Theta(out) <+ Theta(in)/ratio.
In the testbench setup for noise analysis, I am giving a flicker+white noise input to the divider. I want to get the white noise (floor) value at the divider's input port (in). how can I get this value and assign it to a real variable inside the divider module ??
I would appreciate if someone can help me asap.
Thanks, Sunil
