Apr 28th, 2024, 12:14pm
Obtaining the minimum value of an input port in noise analysis (Read 1937 times)
sunmus
Oct 16th, 2015, 4:31am
     I am trying to write a phase noise model of an integer divider. The input and output ports are of type phase and is accessed using Theta. For example, Theta(out) <+ Theta(in)/ratio.
In the testbench setup for noise analysis, I am giving a flicker+white noise input to the divider. I want to get the white noise (floor) value at the divider's input port (in). how can I get this value and assign it to a real variable inside the divider module ??
I would appreciate if someone can help me asap.
Sunil
Re: Obtaining the minimum value of an input port in noise analysis
Reply #1 - Oct 18th, 2015, 9:27am
You cannot. During a small-signal analysis, the models are evaluated in advance and linearized. They are not active during the small-signal analysis itself.
sunmus
Reply #2 - Oct 19th, 2015, 10:11am
Thanks Ken !
-Sunil
