Aug 15th, 2024, 3:43am
A Voltage Variable Resistor in ADS (Read 3723 times)
jade
Mar 21st, 2016, 11:53am
I dont know why but every time I try to something simple in ADS that I can do in LTspice in seconds it takes me hours of frustration and in this case I was unable to figure it out at all..
All I want to do is create a simple linear equation based f(x) resistor whose resistance varies according to the voltage x at another wire label (or port) and run it in harmonic balance.
Thanks in advance for help in this.
« Last Edit: Mar 21st, 2016, 6:59pm by jade »
jade
Re: A Voltage Variable Resistor in ADS
Reply #1 - Mar 21st, 2016, 12:22pm
I got something to work with the following
SDD2P
SDD2P1
I[1,0]=0
I[2,0]=(_v1)/2
C[1]=
Cport[1]=
Well the output of this is still only a current source, I wanted it to be a voltage dependent resistor so back to the drawing board.
« Last Edit: Mar 21st, 2016, 7:00pm by jade »
jade
Reply #2 - Mar 21st, 2016, 7:01pm
Reply #3 - Mar 24th, 2016, 1:21pm
Can you use Verilog-A?  (At one time, ADS used to require a separate license to run Verilog-A models; I don't know if this is still the case.)
