Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 26
th
, 2024, 1:03pm
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› How do you simulate differential s parameters using LSSP?
Previous topic
Next topic
How do you simulate differential s parameters using LSSP? (Read 85 times)
iVenky
Mar 26
th
, 2016, 6:58pm
I am trying to figure out the s-parameters of a push pull class B power amplifier, but the problem is that the input is differential. I am allowed to enter only one input port on the LSSP window in Cadence Virtuoso when I actually have two ports at the input (one for positive terminal and other one for negative terminal which as a phase difference of 180 with respect to the positive terminal). How do you plot differential s-parameters in this case?
I have attached the schematic for better understanding.
IP Logged
Re: How do you simulate differential s parameters using LSSP?
Reply #1 -
Mar 26
th
, 2016, 7:45pm
See
Measuring S-Parameters of a Differential Mixer
IP Logged
iVenky
Reply #2 -
Mar 30
th
, 2016, 12:02am
Hi Ken,
Thank you very much. Didn't actually think that you would reply
I have enjoyed reading up your stuffs
I used a balun at the input to solve this issue so that I had only one input port.
IP Logged
Reply #3 -
Mar 30
th
, 2016, 12:43am
Thanks.
I like to promote the ideal balun. I find that many people do not know about them, or if they do, they don't use them as much as they should. I find life is just better with baluns.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
