Apr 28th, 2024, 10:21pm
iip3 (Read 89 times)
dg12
iip3
Mar 29th, 2016, 7:21am
Hello
I need some help regarding the measurement of iip3 for transconductor or an inverter. If I want to use this transconductor in filters what load should I connect at the output to measure the iip3?? If I need a port at the output how can the resistance value be decided??
Dg
Re: iip3
Reply #1 - Mar 30th, 2016, 12:35am
You should load your circuit based on what it will be driving. You need not use a port.
dg12
Re: iip3
Reply #2 - Mar 30th, 2016, 3:43am
Thanks for the reply... If I'm using a capacitive load, can you elaborate on how to measure iip3 without using port??
Re: iip3
Reply #3 - Mar 30th, 2016, 4:04pm
I'm afraid I don't have the time. Why don't you just try it. You can report back if you get stuck.
