May 19th, 2024, 6:55pm
PM component of a noisy signal in Oscillators (Read 4491 times)
iVenky
Mar 29th, 2016, 8:42am
I am reading the oscillator chapter in RF Microelectronics textbook by Razavi. I have one question that is bothering me for a long time that I am not able to completely understand.  In the chapter on oscillator when he is talking about Conversion of Additive Noise to Phase noise, he considers
x(t)=A cos(wot)+a cos(wo+Δw)t
Where the second term is the additive noise component.
He says that after passing the above signal through a limiter (so that amplitude noise component gets suppressed), we get the following FM (or PM) signal at the output of the limiter.
xlim(t) = (A/2) cos wot - (a/2) cos(wo+Δw)t  + (a/2) cos(wo-Δw)t
I am able to understand the  second and third terms of the above equation, but I don't understand how we are specifically getting (A/2) (in (A/2) coswot) . I mean why is it half of A? This has been bothering me a lot
Thanks in advance
raja.cedt
Re: PM component of a noisy signal in Oscillators
Reply #1 - Mar 30th, 2016, 12:03am
HI-
When you pass through limiter, ideally Am components will supressed because of hard clipping and phase noise will be passed with out having any attenuation. Now by using this you can split the about signal half as an AM and half as FM, hence out put only consists of A/2.
Hope this helps,
Raj.
iVenky
Reply #2 - Mar 30th, 2016, 12:07am
I understand that the phase noise component affects AM and PM equally (which is 'a' in this case). Why does 'A' also divide equally between AM and PM?
Thanks for your help
raja.cedt
Reply #3 - Mar 30th, 2016, 1:21am
Hello-
Please split the whole signal (not only a but also A, because for modulation you cant analyse signals independently) into AM and FM components.
Best regards,
Raj.
iVenky
Reply #4 - Mar 30th, 2016, 3:31pm
Thank you very much for the reply. I thought about this and felt that that should be the reason, but one thing that I don't understand is I am able to explain why 'a' divides equally between FM and AM, but I am not able to explain why 'A' divides equally. Could you please explain me your reason just to get another opinion?
Thanks for your time! It really means a lot to me!!!
Smiley
raja.cedt
Reply #5 - Apr 3rd, 2016, 3:01am
Hello-
Any noise will split into PM and AM equally. But it is not correct to think like noise split but carrier won't, because how can you have spurs without carrier, they always be together otherwise you would call spur as another carrier rather spurs. That's I can tell..
Raj.
iVenky
Reply #6 - Apr 3rd, 2016, 12:06pm
Thanks for the reply. Could you please provide me the mathematical proof for that or some link or book where I can find that?
Thanks a lot for your time
nrk1
Reply #7 - Apr 10th, 2016, 2:26am
The result given below is incorrect. The AM-free signal that has the same shift in zero crossings as A0*cos(wot) + a*cos (wo+dw t + φ) is
A0*cos(wot) + a/2*cos (wo+dw t + φ) + a/2*cos (wo-dw t + π - φ), for a≪A0. There is no factor of 1/2 for the carrier.   Putting either of these signals through a limiter produces the same signal. The limiter's output around the fundamental will be proportional to the latter signal and depends on the limiting amplitude.
iVenky wrote on Mar 29th, 2016, 8:42am:
... he considers
