Feb 7th, 2026, 9:13am
How to reduce/eliminate PSS convergence errors? (Read 2385 times)
iVenky
Apr 09th, 2016, 3:24pm
I am running PSS on Cadence Virtuoso for a wide-range Quadrature VCO. I am facing convergence issues sometimes. Sometimes it works. Do you know the reason behind these convergence issues and how to reduce/solve those?
ULPAnalog
Re: How to reduce/eliminate PSS convergence errors?
Reply #1 - Apr 9th, 2016, 3:51pm
Increasing tstab, adding cmin helps convergence. Also if you are using verilog A models, they should not contain hidden states. A more general discussion on convergence issues can be found here
http://www.designers-guide.org/Forum/YaBB.pl?num=1208694646/1#1
