Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 28
th
, 2024, 11:03pm
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› How to reduce/eliminate PSS convergence errors?
Previous topic
Next topic
How to reduce/eliminate PSS convergence errors? (Read 1678 times)
iVenky
Apr 09
th
, 2016, 3:24pm
I am running PSS on Cadence Virtuoso for a wide-range Quadrature VCO. I am facing convergence issues sometimes. Sometimes it works. Do you know the reason behind these convergence issues and how to reduce/solve those?
IP Logged
ULPAnalog
Re: How to reduce/eliminate PSS convergence errors?
Reply #1 -
Apr 9
th
, 2016, 3:51pm
Increasing tstab, adding cmin helps convergence. Also if you are using verilog A models, they should not contain hidden states. A more general discussion on convergence issues can be found here
http://www.designers-guide.org/Forum/YaBB.pl?num=1208694646/1#1
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
